Sorry in advance for the long post - I want to give as much pertinent info as possible.
I haven't had this boat very long. It has Z150 (2-stroke) motors, one from 2001, the other from 2004. The last several times out, the port engine stumbles badly when I'm trying to get to cruise speed, but eventually (after several minutes) it stops stumbling and runs perfectly until something changes. The change could be that I stop for some reason then go again (all the time with the engine running). It could be that I go from smooth water to rough water. It could be that I make it all the way home with no more stumbling, but then it happens again the next time out.
The stumbling is quite severe at times. For example, 2300 rpm down to 1200 rpm for a half second, or even lower than that. More often, though, it's a drop of 3-500 rpm when I'm trying to maintain 2000 to 4000 rpm.
By the way, every component of the fuel system is separate for each engine - tank, Racor, fuel flow sensor, hoses, everything.
My suspicion is contaminated fuel, or a clogged fuel filter. In addition to the on-engine filter, there is a Racor S3213 filter / water separator between the tank and the engine. I never see any water in the clear bowl on the bottom of the Racor, but when I drain a little of it out of the filter's drain valve, I often see some very, very small bits of black something, but not a lot. (It's not magnetic, and my fuel tanks are plastic, so I'm ruling out rust, at least for now.)
BUT - if it's water in the tank, why am I not seeing any in the Racor's bowl? And isn't there a water sensor in the bottom of the on-engine fuel filter canister? If it's gunk in the tank, how does it ever start running perfectly again after it stumbles? It seems like the stumbling from gunk would be because of a clogged filter, and a clogged filter isn't going to unclog itself just by running, is it?
SO - I will replace the on-engine and Racor filters, and I will pump out a gallon of fuel from the lowest point in the tank after the boat has sat perfectly still for a few days. (It's on a lift, and it tilts backwards, so any water would find its way to the lowest aft part of the tank.) But I have a sneaking suspicion that it's not a contaminated fuel problem, because of the "BUT" paragraph above. What else could it be? A fuel pump? An ignition problem? I can't think of anything else that could make it stumble like that, for such short bursts, but over and over again, for a while, and then "fix itself" for a good long time.
I have the harness to connect to the engine and see the data on my laptop. Is there anything I should be looking at there? The problem never occurs at idle, or anything less than about 1200 or so, and it's very sporadic, so it might be very difficult to see any data on the laptop at the time the problem is occurring.
Thanks so much for taking the time to read this long post, and for any suggestions you may have.
