green67stang
running out of ideas,
I have a 115 4 stroke EFI,
the dreaded "long beep ".
What I've done,
Replaced thremostat and temp sensor.
Replaced all fuel lines from tank to motor.
took it to dealer, codes said low pressure fuel pump.
replaced both low and high pressure pumps.
Tested float passed and good.
Put air pressure from tank fuel line to motor and it held pressure with no leaks.
checked oil sensor and its good
Motor runs great, smooth as can be for about 4 minutes then long beep and shuts off. this happens in gear or nuteral.
throwing parts is getting real old
any ideas or tests I'm missing ?
thanks in advance for any responce..
What I've done,
