1958 35 hp lower end question
airrace48
I've watched all the YouTube videos (multiple times) on re-sealing the lower unit. Pretty straight forward. I agree that the Sierra "spaghetti" cord that comes with
the kit is way to small. McMaster Carr sells great Buta N cord for cheap. Here's my question. The straight slot (kiss of death) screws that hold the skeg are horrible.
They are soft and they are impossible to remove. We've a fantastic shop with all the fun tools and lots of horse sense when it comes to machinery disassembly.
I'm attaching a photo of the problem area. Here's my question. The screw heads are painted the same color as the motor. This 1958 motor was fraudulently sold
to us as a "new" old stock motor, only used twice in 1959 before re-crating. Total lie. That being said it is in fantastic condition. We only paid $1200 for the motor, wiring and original pressure gas tank. My guess is that in 1958 Evinrude DID NOT paint the screw heads individually. Is it possible that Evinrude painted the lower unit after it was assembled? I think not. This might indicate that our motor was painted at a later date. I will say though that if that is the case, they did a fantastic job of hiding the fact that it was re-done. I'm wondering if the paint is contributing to the impossibility of removing the screws. We've used the ol' pound hammer screw removal tool to no effect.
Any pictures of this motor?----Not sure why anyone would pay $1200 for a motor like that.-----I have taken many of those screws out with an impact driver.----As you said you were swindled.
<p>Paint on the screw heads is normal. Far as I know OMC painted these motors as a complete unit with the gearcase already bolted on, so the skeg screws got paint same as everything else. I would not read a repaint into it. Dealer touch up on a scratched gearcase happens too, so the paint is not much of a clue either way.</p><p><br></p><p>For getting them out, forget the screwdriver. Hammer type impact driver, and a slotted bit that fills the slot and is ground flat at the tip so it bottoms out instead of riding up the walls. A bit that is too narrow is what rounds those slots. Heat helps as well. Propane on the head until the paint blisters, then hit it while it is still warm. Whatever sealer they used is 60 years hard by now.</p><p><br></p><p>If a slot starts to chew, stop. Drill the head off, drop the skeg, and the stub usually walks out with vise grips once the load is off it. The screws are still available, so there is nothing to save by fighting them.</p><p><br></p><p>Are the slots still square, or already rounded over?</p><p><br></p><p>thanks</p>
Thanks ever so much. I bought an impact screw remover and it worked like a charm. I bought new 1/4-20 screws from McMaster Carr with 12 point heads and integral (built in) washers. I disagree with the comment made by a member above. The motor, although a complete lie regarding its history is in absolutely beautiful condition. Cosmetically it looks almost new and that means a lot to us since we are putting it on a completely restored Crestliner 14' boat which is now in mint condition. The real problem is that we live in Kalispell Montana, far far away from any market for vintage outboards. My buddy had to drive from Kalispell to Lodi California to pick up the motor. Thats about a 2000 mile round trip. Our fault...
The lower end is now in beautiful condition with a complete re-seal, excepting one glaring problem. The last bushing/"O" ring to be replaced is the shift rod seal. The only YouTube videos that I can find are 20 hp or smaller. In those videos the brass bushing is right up top where it is easily seen and removed... On the 35 hp the seal is buried DEEP in the lower unit casting. It is impossible to see it. Like everything else on this motor it is probably a no brainer but for the life of me I can't figure out how to remove it. The shift rod is in beautiful condition. When I slide it into the bushing it is very "loosey goosey". I cannot imagine that water would not invade the lower unit. It must be replaced. Any help?
Steve in Montana
