1960 Evinrude 40HP Wiring
midloglen
I hope someone can help me. I picked up a 1960 Lark 40HP and it came with a wiring harness and what used to be a switch. I purchased a new switch (the old was destroyed) and started to wire it. At first when I turned the key to the right it immediately tried to start so I moved one of the cables and now it seems to work correctly. Can someone help me with the two leads red & black cables that aren't connected go to. Is there a wiring diagram on this?
I will probably have to replace a bunch of these old wire but they seem to work for now.
Thanks,
Glen
If I recall, early magneto ignition systems used a different switch than later the CDI systems do. You need to verify you have the correct new switch.
