Neal Franson
My lower rebuild went well, and I installed it back on my boat and looks like it is functioning, but the engine is running terribly - it won't idle. I can just get it down to about 2000 rpm and it start to miss and it dies at about 1500 rpm. In taking off the spark arrestor, I see gas squirting out of this pipe above the butterfly and into the carb along with the gas from the jets in the venturi. I don't remember it doing this before. The pipe appears to be part of the carb base and is J-shaped with a hole on the end, The pictures in the manual look like the are U-shaped, and may be some kind of air-bleed device.
Also, I have a bulb pump on the fuel line that I use to get gas into the reserviour when it hasn't been run for a while and the gass goes into the carb, where I thought it would not go past the reserviour when it fills and the float shuts off the flow.
So there are two major outpoints with the carburator. It may have gotten damaged by the engine cover crashing down on it in the wind, but there are no visible cracks. I did rebuild it myself per the directions. I am tempted to put on my Chinese knock-off of an Edelbrock 1409 4 barrel marine carb that I bought last year, but would need a new fuel line from the pump.
