1996 Evinrude E20CREDA 20 hp Outboard lower end started leaking some oil gasket kit needed
muskyking
1996 Evinrude E20CREDA 20 hp Outboard lower end started leaking some oil started leakeing in the barrel when i was testing the idal today i need the correct gasket kit to repair it. and a diagram if there is one. thanks
i got oil in my barrel but not sure if it,s comming from the exhust or not,im have ideal issues and its smoking alot at 50.1 ratio , so im in canada so i put 20liters of gas to 400 mils of oil .
The barrel will get oil / sludge on it from the gas / oil that goes right through the motor.---The nature of a 2 stroke.----Pressure test the gearcase to find leaks if there are any.
i took the prop off and started it and it looks like some oil is comming from there so i think all i need is the o ring correct? can someone help me find one i dont need the hole gasket set just the o ring and im trying to search a how too on removing it .
im not sure im new at this,all i know is there is a bit of oil comming from the prop very little but enough to need it fixed , all i know is the 3 seals i think need to be replaced im going by this vid.https://www.youtube.com/watch?v=lXscDqFyD5c
comming from the prop , i mixed the gas oil 50-1 and it does smoke i think to much so i cut it back a bit on oil, put after taking the prop off it still drips oil and running the motor in a barrel iv never had oil on the top of the water like that before. the next issue i got is from what i see you need a puller to pull the sleave out around the prop and where would i get that, the 3 seals in the pic at the bottom are the ones i need to change
