new to engines and boating.. i have changed lower impeller because it was running hot and changed thermostat and thermo switch and now a good flow of water, spark plugs, coil packs, carb rebuild, new fuel pump. when i get to the ramp it fires right up and have no issues. will troll around for an hour or so and then the problems begin. i will try to start the engine and won't start, wait and try again etc over and over.. i have to put it in neutral and rev it up and basically slam it into drive. shutters, kicks, hesitates most of the way back to the ramp. once i idle down or get to dock it dies on its own and then i have to use trolling motor to get on the trailer. i have a friend who is a retired mechanic that has tried to help. have compression, spark and timing and idle is good. thought it might have been bad gas, but used new gas in a new gas tank and again this morning used troller motor to get on trailer. any suggestions
