2005 Volvo Penta 8.1 gxi - ecm issue
Aaronandjenny
Any help would be appreciated!
I have a constant misfire on #5 cylinder.
Checked all the wires going to the emc, all check out good.
Replaced coil pack ,wire, and plug. Swapped coil pack, wire, and plug with one that is working.
Spark plug is wet after running for a few seconds. Will not get over 4000 rpm.
The boat is on Grand Lake O' the Cherokees in Oklahoma.
Only other issue has only happened twice in the last month. Running the boat and it acts like You just pulled the kill switch, switch batteries to off and on again, everything is fine, except for the #5 plug not firing.
Thank You!
Welcome
Looks like you have a bad connection or ECM
Each injector has a designated wire from ECM, Trace your wiring
