red_georgia
Have quite a perplexing issue. Boat is a 2006. Never had a engine running problem before. On the lake this weekend, during first few hours, noticed I was struggling to get on plane (taking 3 times as long as normal) and seemed to be lacking power. Once on plane, could only get to about 3K rpms. Stopped for lunch. After lunch about 20 miles+ from home, could NOT get on plane. Could not get motor to accelerate past 1500rpms and anything above 1000 the motor was shaking pretty bad, and occasional backfire and sounded like running really rough with potential mis-fires. Assumed I was in limp mode and we crawled all the way back for 3 hours at 9-10 miles per hour.
Having replaced a bad fuel pump two years ago, I was guessing the cheap Chinese one I bought was failing again. Got fuel pressure test kit on it and it passed both key on, no load, and loaded tests with fuel pressure staying 40-45psi the entire time. When under load in water, same motor defect conditions exist even though fuel pressure is within spec.
Ordered Marine Scan tool which I put on it this morning. NO DTC's other than high voltage on trim sending unit. Trim gauge hasn't worked in 15 years so I'm guessing that isn't the problem. When running, it is not over heating, oil pressure is fine, and the two parameters for engine derate are both off. When in neutral, or in gear but just spinning air, motor runs normally and accelerates to 3K RPMs with no problems (just spinning air so didn't push it higher). Motor not vibrating, acceleration is smooth, and TPS demand and output looks correct on scanner.
So, take it back to water, with scanner connected and same defect condition under load occurs. Motor shakes, struggles to go past 1,500 rpm and sounds terrible. Hi idle without load still revs correctly in the water.
So, I'm stuck.... with no codes and running fine without load, doesn't it have to be the outdrive? Under load potentially eating itself/binding and overpowering the motor trying to turn it? I'm going to drain outdrive tomorrow and look for glitter/water but what else could it be?
Perplexed?????
Perplexed?????
