Hello
I had my boat out last week, and the outboard ran fine for around 25 minutes. The engine then cut out, and I couldn’t get it restarted, it was trying to start up but wouldn’t take over.
I have just had a go at starting it on muffs, and it started up first time. I did notice the primer bulb on the fuel line is now leaking and has air inside, which it wasn’t before.
I assume this is something heat-related, could replacing the fuel lines and bulb fix this issue though or is it likely to be an issue within the engine?
I’m hoping someone can point me in the right direction - engine has a strong telltale stream and had a new impeller fitted before having it out last week.
