Ok, so I found a 1987 Johnson 90hp V4 (700 dollars) to replace my 1983 70hp Johnson.
Did the compression test and spark test. Passed with flying colors.
When I checked the tilt and trim (worked great). I noticed water leaking from the 2 very small holes at the very front of the lower unit.
Both of these holes are about the size of a needle tip.
Wondering if this is a sign that the lower unit should be redone?
