Lurked here for ten years at least great forum
I have a 2003 bf-225 great motor
Finally screwed up the courage to change the belt.
I will point out things I did not figure out even with the shop manual
First adjusting the belt tension is dead easy. Pull plugs and inlet silencer set engine to TDC. Note crank pulley mark ensures TDC on intake stroke. Loosen tension pulley bolt. Watch tensioner move. Torque tension pulley bolt. Done.
If tensioner doesn’t move it is bottomed out. You need a new belt.
To change belt pull throttle body and pulley covers
Hard part break crank pulley bolt loose. You need the Honda tool. Less than 100 bucks Amazon
You also need to apply 500 ftlbs torque this means a three foot 3/4 drive.
Pop it off
Thread new belt. All slack must be at the tensioner pully
Observe tensioner pulley take up slack, torque it down. Rotate clockwise check for clean smooth and operation.
You are done.
Again great forum thx
Pop it off
You are done.
