I'm going to be installing a brand new DF90A on a boat that I'm building, so I'm trying to make sure i have all the required hardware so I'm not scrambling when the engine shows up.
I'm stuck on exactly what size bolts I need, I know it's M12, but beyond that there are two dimensions that are not clear to me:
What is the actual hole size in the motor bracket? I'm assuming it's more than 12mm to account for the unthreaded shank of the bolt.
How deep is the hole in the motor bracket, so I can account for getting the correct length bolt to go through my transom.
My transom is 1/4" thick with a 3/8" doubler plate where the engine sits, so total 5/8" transom thickness. Just trying to figure out the bolt size and drill size I need to make sure I can get this mounted without being angry.
