Evinrude 30 hp
mapleleafnut
"Hi
I have a 1998 evinrude 3
"Hi
I have a 1998 evinrude 30 hp outboard engine.
when you put her in foward gear she will only work till 1/4 trottle, after that she will rev on the engine. I removed the drain plug in the leg and found the oil to be black.i am thinking the foward gear is gone.my question is do i have to replace they whole leg, or just the gears.and can some one tell me wher i can find info on how to do this work my shelf. thanks"
"Provided it is not actually j
"Provided it is not actually jumping out of gear it is most likely a spun prop ie the rubber hub has failed.
Mark the end of the shaft and the prop, take it for a spin and then check the marks. If they no longer line up then its a spun prop.
If you do need to work on the gears then get a manual Preferably a manufacturers one which you can get from Marine Engine.. See the link at the top of the page to manuals."
"Lorne.... Gears do not fail i
"Lorne.... Gears do not fail in the senario you describe. If a gear problem, the engine would jump out of and back into gear. It would feel that you were constantly hitting an underwater object."
"Hi.
I took your advice,put o
"Hi.
I took your advice,put on a new prop. every thing working fine. thanks again for all the help, much appreciated.lorne"
