Evinrude E-Tec 90 HP Trim and Tilt
Rory Livingston
Hi. I need to top up the Trim and Tilt fluid level but can't locate the fill point. I removed a bolt (fluid came out) but I don't believe this is the fill point as it is low on the unit. I am not the most mechanical but will give it a go. any help appreciated as I can't find video on Youtube specific to Evinrude motors
Tilt the engine all the way up,it's a plug in the resevoir next to the cylinder that you need a straight screwdriver to remove.Fill untill the fluid runs out of the hole.
thank you. only problem is that the screw sits behind the motor bracket......I can't access it without taking out the whole unit.....very weird
My 2006 75 is the same way. You need to use the engine brace to support the motor tilted up and then remove the pin that attaches the trim cylinder to the motor. You can then rock the trim unit forward to get acess to the screw. Pretty messed up since you need to re-attach it and work it up and down to bleed air out. Rinse and repeat.
Wow! I have a 2009 etec 90 with the same setup. My tilt is not working and I think my seals are leaking. The last estimate I got was $1300 to replace it.
This is the fill screw, I believe. It is restricted from being removed by the engine mount.
I have the same issue. The motor can be titled up further than what the trim control buttons allow. You need to unscrew the relief screw on the side of the tilt pump (it’s inset quiet a ways and should be marked) this will allow you to push the motor right up, almost to horizontal and then either brace the moto or flick the trim cam down to lock it in that position. This should give you enough space to remove the fill screw on the side of the reservoir to fill it until the fluid bleeds out. Put fill screw back in, then screw the relief screw in, let the motor down, cycle it up/down a few times and then repeat the process again to ensure you’re filling the pump and lines fully.
Is there a solution for a seemingly inaccessible trim fluid fill screw cap? With the motor fully tilted up..bracket engaged, the motor mount obstructs access to the cap for servicing. Suggestions?
