jeffneville
"I have a 1979 Grand Banks 36
"I have a 1979 Grand Banks 36 with twin Ford Lehman 120's, 6 cyl. The port engine is overheating by 20 to 30 degrees. I have done extensive work to try to find out the problem and at am the end of my rope for a solution.
Here is a summary of the work done - all 3 raw water heat exchangers have been taken off, inspected and back flushed. Then these were exchanged with the starboard engine and still the port engine overheats. The riser has been replaced - the old one didn't show very much accumulation. Engine temperature gauge reads the same at main steering station and bridge station. Also, it has been connected to starboard engine and shows normal temperature. The temperature gauge sensor has been exchanged with the starboard one and there is no change.
The thermostat was replaced but no improvement. The new one has also been exchanged with the one in the starboard engine and no change.
The raw water impeller pump has been rebuilt. The raw water intake has been exchanged with the starboard engine one. No change - the problem persists. Raw water exhaust on port engine looks about the same as the starboard.
The port engine sounds like it is running well - sounds the same as starboard engine. No noticeable leakage of oil or coolant.
We have run sea trials at 1200 rpm and 1560 rpm (chosen arbitrarily). At the lower rpm, temperature is good. At higher rpm, the reading goes to 210 F.
I need to get this problem solved as soon as possible. Any suggestions would be greatly appreciated.
Jeff Neville [email protected]"
