Honda BF150a
Murph68
I’ve an over hearing problem with my BF 135a
Today as I was changing the grommets on the drive shaft from the lower end I decided to check the water pump again. All looked good but I removed the base plate and underneath at the base of the drive shaft is a cylindrical shaped unit with 2 10m bolts on top. The top of this is in very bad shape with lumps missing around the top of it?
What is it? Would this be affecting my water flow?
For some reason I can’t upload any pics or vids apologies.
Cheers Ronan.
from your description it is the top seal cover of lower unit which holds the water and gear oil seals for the drive shaft. the seal cover wont effect water flow but if there are sand and shells packed around it restricting water intake which could also be cause of the corrosion of the cover you are seeing.
Cheers for that mate.I’ll order one up tomorrow
