William Miller
Mercruiser 350 MAG MPI* Bravo 3 , Gen3 Cool Fuel, Raw Water Cooled, 3 point drain
I am in the process of tracking down a over heating issue on my Starboard engine.
I have replaced the impeller and thermostat
I have the smart craft (System view) which show water pressure on both engines side by side.
The readings have been low since I bought the boat 2006 new.
They do fluctuate as expected, but are off by a factor of 10.* (I believe as I watch the readings go from about .05 at idle to about 1.5-2.0 at cruising speed.
The overheating issues is new this spring. At this point I believe there is a blockage in one riser.
The readings never bothered me untill now that they would be usefull.
What I have learned:* The water pressure sensor is on the power steering cooling tube on the back of the engine.* I can feel it, but cant see it.
The wiring diagram indicates that it is 5 volts and wired directly to the ECM
The original part number has been superceeded (Thus I wonder if there was something wrong with the original batch.
Earlier engines had a sensor located on the output tube of the raw water pump.
My raw water pump has blue drain plugs in both the inlet and outlet side. (It's a brass pump)
The plugs are very difficult to get to due to the engine mount stringer and the Cool Fuel Box.
In the mercruiser parts diagram it indicates the the blue plugs are 0.5"-13 which I assume means 1/2" with 13 threads per inch.
This is a very strange pipe size.
So, how do I find a adapter to plumb this to a 0-30 psi mechanical gauge?
Thanks for any help and suggestions.
Anyone know how I can get the specifications for the old and new water pressure sender?* It would be nice to test the output.
I have ordered the mercruiser engine manual, but somehow I doubt they have such detailed info.
Does Mercruiser send out Techmical service bulitens like car manufacturers do?
Thanks again!
Thanks again!
