Roadking57
Eng S/N 0B776858, 1988 4.3L LX. Symptom: Runs on lake at 3/4 throttle all day. When I try full throttle it tries to accelerate then falls flat. Bring back to 3/4 its happy. Starts and idles great. I have rebuilt the carburetor. I think the fuel pump is original. I want to replace it just to eliminate a potential problem. However,
the pump is attached inverted. I have replaced the little stone filter in the bowl. All of the information I can find on the net says it should not be mounted inverted. The V6 block is not the same as a SBC as far as the mount surface. This block mount pad is nearly 45deg slanted.
Did GM design this marine engine with it inverted? What are your thoughts Gentlemen?
