I will go out Saturday and re=check the plug wires. Take my timing light (which does have the advance feature,the book just said its not reliable). Take a helper with me. And I will also do another compression test. Couple of dumb questions but wanna make sure its right.
1. my distributor has 2 sets of numbers (large and small numbers). I have been using the large numbers since it is a normal rotatation + correct?
2. If boat is in the lake, and I am suppose to be 32 before tdc at 3700rpm is it ok to do that in the lake?
and if i have to move the dist to make it the 32 btdc, and then at idle it is not at 8btdc..........whats the next step or problem?
...but go to give it gas and no power, not even close to a plain. But, no popping noise.
LOL I know thingy is not a technical term. Lemme clarify in the point of a question. If the balancer mark is matched at zero on the timing pointer, and the #1 cyclinder is at top dead center. The distributor inside with the copper arm should be set pointing towards the #1 cyclinder. As well as the number one on the distributor cap pointed in the number one cyclinder direction. right?" I turned the balancer to top dead center. I instaled the distrubutor with the top thingy pointed toward the number one cyclinder. lined up the top with the thingy and put the top back on. So I start the engine and it wont idle. "
Well, the thingy is not pointed to #1 cylinder. It`s located where #1 is on the dist cap. Starting from #1 on the cap and going clockwise is the firing order. 1,8,4,3,6,5,7,2. The balalncer is turned so that #1 cylinder is coming up on compression and you locate the timing pointer`s "0" to the line on the balancer.
oops, sorry just realised my CAPS LK, sorry for shouting.....
Mistake? Hmmmm. LOL
Question for everybody; In this model of 350 SBC, can a piston make contact with a valve if cam shaft out a few teeth?
Unlikely if off by one tooth only, IMO.
Ricardo, could this happen with Quench effect pistons?
I'll take it that you are kidding..... but in response:
No more likely than with any piston. A Q/E style piston should offer the same relief clearance. The only area that actually changes, would be the area that comes up under the wedge of the cylinder head.
A Flat Top piston, for example, can offer a Q/E when the deck clearance is correct, and correct head gasket is used. This should not create any change to valve relief.
BTW/FYI....., the F/T should NOT be used with the small chamber cylinder heads for marine use.... Period!
There is NO pvc on a marine engine that I am aware of or ever seen. It is a hollow part and it looks like a pvc used on automotive but it is hollow!!! Just lets the pressure out and there is one on each side with hoses that direct the ventilation to the flame arrestor.
This just came up on the BOC forum. Apparently Merc does use a PCV Valve on several engines. Why????...... I don't know! It is unnecessary, IMO.
"I think what we have here is a failure to communicate"..........lol
I also suspect (with no mal intent) we have someone who needs some special guidence and possibly some hands on experience with the motor and all its components....
Amen!
Again, this would be important to check, but NOT using that method!Has you harmonic balancer slipped, mark is no longer at TDC? stick sumtim into #1 plug hole and confirm mark at 0 deg when #1 @TDC.
Buy or borrow a light with an advance feature
In addressing both quotes above:Find a timing light that has an adjusteble scale My sears timing light has a knob on the end that you can adjust for that purpose
1. Please explain this. You have the M/C TB EST Ignition system, correct? Yes.... it will be CW rotation, as are all of these!1. my distributor has 2 sets of numbers (large and small numbers). I have been using the large numbers since it is a normal rotatation + correct?
3. and if i have to move the dist to make it the 32 btdc, and then at idle it is not at 8btdc..........whats the next step or problem?
Wow.... lots of concerns here. Not sure where to begin!Ok time to help my gurus understand some of your questionsand I do appreciate the help.....
1. motor compression after the rebuild was fine 140-150 all cyclinders
2. originally the exhaust manifold leaked water into the engine. (milky oil) when i winterized, I didnt know it leaked. when i tryed to start motor was locked up.
3. OK the noise was actually backfiring from the carb (mechanic said it was most likely the camshaft). well i took the camshaft out to replace with a new one. but the original was just fine. After having the backfire noise still, I spoke with mechanic and he said maybe my timing chain was off by a tooth or 2. So i removed balancer,pump,timing cover and rotated #1 to tdc. Low and behold it was off by 2 teeth (not lined up). So i fixed that and got it lined up perfectly. like a dumb ass I didnt want to pull engine, so i kinda forced the timing cover and gasket into the slot (I know dumb ass). That is why I do not have a good seal on the timing cover!!!
4. I got the leakdown tester to see if any of the valves were stuck since I did nothing to them, presuming they might have had a little water in them. when I showed the heads to the machine shop, the guy said they looked fine. but he did not do any type of test on them. (wont use them again).
OK, so following the suggestions. I will do a compression test sunday after i make a starter switch. Can i just start the motor (with bad gasket).
And let it warm up for about 1 minute without water running??? And then do the test.
or do i need to fix the gasket first, and also run water???
