2007 BF225.
When pulling out of marina today motor started to stumble so I gave it some throttle but then I heard a beep and the motor shut down completely.
When I try to restart nothing happens. The ignition doesn't even do the normal beep when I first turn the key and the battery/water/oil lights don't come on either.
I noticed the trim/tilt only works if the key is in the off position. There's still power to everything else and if I jump the starter solenoid the starter spins but doesn't engage the motor.
Also noticed there is more than normal resistance if I try to shift into forward or reverse. Not sure if that's just because the motor is off though.
Tried wiggling wires and the ignition key and checked most of the fuses I could before SeaTow showed up but still no luck.
Any ideas?
Any ideas?
