theydrewa31
Hello Gentlemen!
I am currently restoring a Starcraft Islander 221V with a 1988 4.3 Liter Cobra engine. The hull material is 5052 riveted Aluminum.
I'm starting service on the engine soon but trying to get some questions answered ahead of time so I can order parts and supplies so they arrive when I'm getting ready to re-install the motor, as I have a short timeline of availability to get this stuff done.
I'll start with some photos to get you up to speed with how she was previously set up. Below is a picture of where the engine is mounted in the boat. The engine is sitting there under the tarp. I moved the engine so that I could remove the old transom wood which had rotted away to almost nothing. I'll be replacing the transom wood with 2 pieces of 1" marine ply laminated together with epoxy. On this model of boat there is only a layer of aluminum on the outside of the transom. The motor mounts are mounted onto the aluminum stringers shown in the red circle in the photo below.
Only the front motor mounts were supported. The rear motor mounts were previously not used. I know that the motor was changed out at some point, and I assume that the outdrive was as well. Being completely honest I don't have much faith that the previous owner really knew what he was doing judging by most of the work I have seen on the boat, so I am curious if it is normal to only have the front motor mounts attached?
The front mounts had a block of plywood underneath, along with a piece of lauan. Is it common to use blocks for the motor mounts on aluminum boats? My first thought was that it was done as a spacer, but now I am curious if it was done to isolate the metals to limit galvanic interaction? A magnet does not stick to the feet of the motor mounts so I had assumed that they were aluminum. If it is necessary to have something there to isolate the motor mount I will probably use some kind of hardwood like oak, but I am open to recommendations for that.
