135ETL75E
I just bought a boat with this motor, and it goes up but not down with the switch on the throttle arm. I tried a new relay and that didn't work. I tried applying 12V to the blue wire coming from the tilt motor and IT WORKED. I figured it had to be a bad switch or wire, so I bought a new surface mount switch and connected it to the 3 wires under the dash(where the throttle arm switch were connected) and still same. So I thought it has to be a corrupt blue wire from the switch to the relay and replaced that. It still doesn't work. I don't know what else it could be. Any ideas?
I imagine bypassing that side of the relay to run a wire directly up to the switch would probably melt something without a resistor or diode or something else I don't understand inline
Stephen.
Stephen.
