Opinion on spark plug cap, old school pin or resistor type
i have a 76 evinrude 135hp, wondering if i should use the old school press in pin style cap or the resistor type screw in. Thanks
what?? :)
That engine demands Champion QL77JC4 plugs gaped at either .030 (long life)... or... .040 (strong spark)
Use the type plug connectors the engine calls for (Spring Connector & Boot).
I have always thought I supposed to be using the surface gap UL77v or L16V, so it's ok to use a plug I can gap?
Those type "surface gap plugs" have no heat range regardless of their numbered designation. They're a cold running plug which is prone to fouling. The Champion QL77JC4 plugs set as mentioned were recommended to be used by OMC via a bulletin many years back.
Trust me, I've been a serious minded technician (fancy word for a mechanic) with OMC since 1960 (retired 1991). I know of what I speak.
Joe would you also put these in a 1977 140 ?
my friend has the 140 with the surface gap, I did not know about any of the bulletins for the v4's.
