Johnson jon boat
Model J60TLENE on a RedFin 16 Center Console.
I have re-wired the console. There are several wires left over that seem to go nowhere since I have
run many boat accessories to the battery directly. The ignition switch is working properly. The engine status horn is working
when ignition switch is turned on. The engine is turning over but not firing. New plugs, new fuel pump. The engine was
starting and running well prior to starting the re-wiring. The only wire that seems to matter is a purple wire at the ignition switch.
Are there possibly any wires in the harness coming from the engine that I may need to be connected somewhere in the dash
panel that would prevent spark generation. Harness ground is being used. The ever popular RED wire in the harness is not showing
any voltage when ignition is turned on. The main engine fuse is good. I just feel that there is a wire in the harness that
needs to be put in the loop somewhere. I appreciate any help on this.
THANX Guys.
THANX Guys.
