90 hp johnson fuel location?
Look the motor over carefully.-----Hose might go direct to the fuel pump.----Also determine if oil injection is in service.---------DEtermine whether oil injection is tested ready to go or if it needs to be prepped / commissioned.
pretty sure this is the VRO? i did not intend to use it. however see the hole on the engine, is that where there should be and adapter for the fuel hose to connect?
Looks to me that someone decided not to use the VRO system, they have a high failure rate. I eliminated it on my motor and now just do premix. So a regular fuel pump may have been installed.
racerone say pic three is the fuel/oil line connector on the engine side. trying to find a connector for the hose that matches?
