Kahuna1968
i have a 1996 johnson 2 stroke, just put it on and trying to locate the fuel intake connection
pretty sure this is the VRO? i did not intend to use it. however see the hole on the engine, is that where there should be and adapter for the fuel hose to connect?Look the motor over carefully.-----Hose might go direct to the fuel pump.----Also determine if oil injection is in service.---------DEtermine whether oil injection is tested ready to go or if it needs to be prepped / commissioned.
i cannot seem to find a connector for the hose that would fit that.picture #3 is where fuel / oil connect.
any suggestionsi cannot seem to find a connector for the hose that would fit that.
racerone say pic three is the fuel/oil line connector on the engine side. trying to find a connector for the hose that matches?Looks to me that someone decided not to use the VRO system, they have a high failure rate. I eliminated it on my motor and now just do premix. So a regular fuel pump may have been installed.
so you are saying that i can just use the hose with a clamp and slide onto the amber plastic manifold? not to us any quick connect type connector? this is for my fuel line.????----The hoses slide on to that amber plastic manifold.
